Renardo18
4 years agoStratix 10 : Critical Warning: DDR Timing requirements not met
I have two DDR4 ('DDR A' and 'DDR B') in my project, and I am using two DDR4 EMIF controller for Stratix 10.
My problem is the 2 of them don't meet timing, the compilation report gives this kin...
Renardo18
4 years agoHi Adzim,
You said : " Then the timing closure issue is between the EMIF IP and other design block.". How do you know that?
From what I see, the timing closure issue is between :{memory_ddr4x72_wrapper_a|u0|emif_s10_0|emif_s10_0|ecc_core|core|ecc|internal_master_wr_data[xxx]}
and :{memory_ddr4x72_wrapper_a|u0|emif_s10_0|emif_s10_0|arch|arch_inst|io_tiles_wrap_inst|io_tiles_inst|tile_gen[xxx].lane_gen[xxx].lane_inst|lane_inst~phy_reg1}
So between emif_core|ECC|internal_master_wr_data AND emif_core|tile|lane|phy
So not between the core and another design block?
I have added the pipeline asked in the report.
I am relaunching the build.
