DRaineyNAL
5 years agoSPI Slave to Avalon-MM escape problem
I am using the SPI-Slave to Avalon-MM IP to communicate with a MAX10 FPGA from a host processor (current test is on DE10-Lite board). In general everything is working. I can read and write devices an...
- 5 years ago
I actually just resolved this issue. The problem was not in the write packet. The problem was that when I read the value back I was not properly handling the escape at the end of the packet. This problem is resolved.
DRaineyNAL
5 years agoI actually just resolved this issue. The problem was not in the write packet. The problem was that when I read the value back I was not properly handling the escape at the end of the packet. This problem is resolved.
