17 years agoSOPC PWM Module
I would like to add some PWM outputs to my NIOS system. I could not find a module in the SOPC builder and hardly anything on the web. It is somehow unbelievable that not many users need PWM outputs on their microprozessors. Pls give me advise how to proceed. Thanks, Wolfgang P.S.: I only post this message in the IP Discussion, because the NIOS forum is obiously down.2 Replies
I make a simple pwm module (only 1 output).
is in use in a cyclone III, without problems. 3 modules: ************************ pwm.v ************************ //modulo generador PWM //toni salguero //inicio: 15 de junio de 2009 module pwm( rst_n, clk, //bus avalon av_cs, av_rd, av_wr, av_datain, av_dataout, av_addr, //señal de salida PWM pwm_out ); input rst_n; input clk; //bus avalon input av_cs; input av_rd; input av_wr; input [1:0]av_addr; input [31:0]av_datain; output [31:0]av_dataout; //señal de salida PWM output pwm_out; wire pwm_enable; wire [15:0]pwm_divisor; wire [7:0] pwm_width; pwm_avalon_slave_if pwmif (rst_n, clk, av_cs, av_rd, av_wr, av_addr, av_datain, av_dataout, pwm_enable, pwm_divisor, pwm_width); pwm_control pwmc (rst_n, clk, pwm_enable, pwm_divisor, pwm_width, pwm_out); endmodule ************************ pwm_control.v ************************ //modulo de control del pwm //toni salguero //inicio: 15 de junio de 2009 module pwm_control( rst_n, clk, pwm_enable, pwm_divisor, pwm_width, pwm_out ); input rst_n; input clk; input pwm_enable; input [15:0]pwm_divisor; input [7:0]pwm_width; output pwm_out; wire pwm_clk; reg [7:0]contador; reg [15:0]clk_div; //generador del clock del modulo always @ (posedge clk or negedge rst_n) begin if(~rst_n) begin clk_div <= 0; end else if(pwm_enable) begin clk_div <= clk_div+1; if(clk_div == pwm_divisor) begin clk_div <= 0; end end end assign pwm_clk = (clk_div == 0 ) ? 1'b1 : 1'b0; //señal de salida always @ (posedge clk or negedge rst_n) if(~rst_n) begin contador <= 0; end else if(pwm_enable) begin if(pwm_clk) contador <= contador+1; end else contador <= 0; assign pwm_out = (contador <= pwm_width) ? 1'b1: 1'b0; endmodule ************************ pwm_avalon_slave_if.v ************************ //interficie con el bus avalon //toni salguero //inicio: 15 de junio de 2009 module pwm_avalon_slave_if( rst_n, clk, chipselect, read_n, write_n, address, writedata, readdata, pwm_enable, pwm_divisor, pwm_width ); input rst_n; input clk; input chipselect; input read_n; input write_n; input [1:0]address; input [31:0]writedata; output [31:0]readdata; output pwm_enable; output [15:0]pwm_divisor; output [7:0]pwm_width; reg delayed_cs; reg pwm_enable; reg [15:0]pwm_divisor; reg [7:0]pwm_width; wire cs; //retardo de cs always @ (posedge clk or negedge rst_n) if(~rst_n) delayed_cs <= 0; else delayed_cs <= chipselect; assign cs = chipselect & ~delayed_cs; //carga datos en el registro de control always @ (posedge clk or negedge rst_n) if (~rst_n) begin pwm_enable <= 0; pwm_divisor <= 0; pwm_width <= 0; end else if (cs & ~write_n & (address == 0)) begin pwm_width <= writedata[7:0]; end else if (cs & ~write_n & (address == 1)) begin pwm_enable <= writedata[31]; pwm_divisor <= writedata[15:0]; end //lectura de los datos //datos de salida assign readdata = 32'b0 | {32{(~read_n & chipselect & (address == 0))}} & {24'b0, pwm_width} | {32{(~read_n & chipselect & (address == 1))}} & {pwm_enable, 15'b0, pwm_divisor}; endmodule Toni Salguero - Altera_Forum
--- Quote Start --- I would like to add some PWM outputs to my NIOS system. I could not find a module in the SOPC builder and hardly anything on the web. .. Pls give me advise how to proceed. --- Quote End --- You should read close topic (http://www.alteraforum.com/forum/showthread.php?t=5892). There is link to literature there. And I attached component with PWM outputs to SOPC (systemavalon_slave_pwm.zip)
