13 years agoSoft ip core design
Hi, Basically i want to design one fifo soft ip core which should work any vendor FPGA.(I know so many fifo ip core's are there in market:-P). Already i designed fifo(256x8) using VHDL code and sa...
13 years ago --- Quote Start --- FWIW: Contrary to a statement in that document, if you do concurrent read and write to the same location with the same clock but without 'old data' configured you can get a mixture of the old and new values - you aren't guaranteed to see one or the other. (OK - that was actually two clock mode with both clocks being the same...) --- Quote End --- I'm afraid we are getting diverted from the original post. Basically I need someone to explain me the steps/process/tools involved in designing a IP core and how different it is from a RTL design. Can I get a reference design for the same? Thanks in advance, Karthi. S
