14 years agoSlow DDR2 reading
Hello, I'm implementing a FIFO using the DDR2 RAM in a 3C120 development board. Basically, I have two memory pointers, one for writing and one for reading, and I sequentially write 255 64-bit word...
14 years agoMight be worth tring to find out if the memory controller is buffering writes in order to do a burst write to the DDR memory, but always doing an actual read transfer.
Some simple timing calculations I did with the SDRAM interface implied it initially latched a write request, then moved it into a burst sized 'write assembly buffer' before finally writing out the accumulated burst. (It would definitely accept 3 random writes without additional waits.) Read requests, of course, cannot be latched the same way! But could be quickly responded to from a single 'burst read' buffer. I was only interested in the timing for random reads and writes.
