14 years agoSimulating the I2C Controller
Hello Everyone, I am trying to simulate the I2C controller, but have problem as there is no slave to generate the acknowlege back. Can Anyone tell me how to get around this. Thanks...
14 years agoDefinately doable in Modelsim. It can run Testbed scripts, which is where you bring in the entity that needs testing - then simulate whatever response the I2C would give.
In my case I needed some MDIO response at 38527 ns. Here's one I just used myself:library IEEE;
use IEEE.STD_LOGIC_1164.all; use IEEE.STD_LOGIC_UNSIGNED.all;
entity device_testbench is
end;
architecture test of device_testbench is
component device is
PORT (
CLOCK_50 : IN STD_LOGIC; -- 50 MHz
KEY : IN STD_LOGIC_VECTOR(3 downto 0);
SW : IN STD_LOGIC_VECTOR(17 downto 0);
LEDG : OUT STD_LOGIC_VECTOR(7 downto 0);
LEDR : OUT STD_LOGIC_VECTOR(17 downto 0);
LCD_RS, LCD_EN : OUT STD_LOGIC;
LCD_RW : OUT STD_LOGIC;
LCD_ON : OUT STD_LOGIC;
LCD_DATA : INOUT STD_LOGIC_VECTOR(7 DOWNTO 0);
ENET0_RST_N : OUT STD_LOGIC;
ENET0_MDC : OUT STD_LOGIC;
ENET0_MDIO : INOUT STD_LOGIC;
ENET0_RX_CLK : IN STD_LOGIC;
ENET0_RX_DV : IN STD_LOGIC;
ENET0_RX_ER : IN STD_LOGIC;
ENET0_RX_CRS : IN STD_LOGIC;
ENET0_RX_COL : IN STD_LOGIC;
ENET0_RX_DATA : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
ENET0_INT_N : IN STD_LOGIC
end component;
SIGNAL CLOCK_50 : STD_LOGIC; -- 50 MHz
SIGNAL KEY : STD_LOGIC_VECTOR(3 downto 0);
SIGNAL SW : STD_LOGIC_VECTOR(17 downto 0);
SIGNAL LEDG : STD_LOGIC_VECTOR(7 downto 0);
SIGNAL LEDR : STD_LOGIC_VECTOR(17 downto 0);
SIGNAL LCD_RS, LCD_EN : STD_LOGIC;
SIGNAL LCD_RW : STD_LOGIC;
SIGNAL LCD_ON : STD_LOGIC;
SIGNAL LCD_DATA : STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL ENET0_RST_N : STD_LOGIC;
SIGNAL ENET0_MDC : STD_LOGIC;
SIGNAL ENET0_MDIO : STD_LOGIC;
SIGNAL ENET0_RX_CLK : STD_LOGIC;
SIGNAL ENET0_RX_DV : STD_LOGIC;
SIGNAL ENET0_RX_ER : STD_LOGIC;
SIGNAL ENET0_RX_CRS : STD_LOGIC;
SIGNAL ENET0_RX_COL : STD_LOGIC;
SIGNAL ENET0_RX_DATA : STD_LOGIC_VECTOR(3 DOWNTO 0);
SIGNAL ENET0_INT_N : STD_LOGIC;
begin
-- instantiate device to be tested
device0: device port map(CLOCK_50, KEY, SW, LEDG, LEDR, LCD_RS, LCD_EN, LCD_RW, LCD_ON, LCD_DATA,
ENET0_RST_N, ENET0_MDC, ENET0_MDIO, ENET0_RX_CLK, ENET0_RX_DV, ENET0_RX_ER, ENET0_RX_CRS, ENET0_RX_COL, ENET0_RX_DATA, ENET0_INT_N);
-- Generate 50 MHz clock, 20 ns cycle
process begin
CLOCK_50 <= '1';
wait for 10 ns;
CLOCK_50 <= '0';
wait for 10 ns;
end process;
-- Operate switch
process begin
sw(17) <= '1';
wait for 100 ns;
sw(17) <= '0';
wait;
end process;
-- MDIO Output from PHY chip
process begin
ENET0_MDIO <= 'Z';
wait for 38527 ns; -- This is where we simulate response from the PHY
report ("Faking PHY response");
ENET0_MDIO <= '0';
wait for 400 ns;
ENET0_MDIO <= '1';
wait for 400 ns;
ENET0_MDIO <= '0';
wait for 400 ns;
ENET0_MDIO <= '0';
wait for 400 ns;
ENET0_MDIO <= '1';
wait for 400 ns;
ENET0_MDIO <= '0';
wait for 400 ns;
ENET0_MDIO <= '0';
wait for 400 ns;
ENET0_MDIO <= '0';
wait for 400 ns;
ENET0_MDIO <= '1';
wait for 400 ns;
ENET0_MDIO <= '0';
wait for 400 ns;
ENET0_MDIO <= '1';
wait for 400 ns;
ENET0_MDIO <= '0';
wait for 400 ns;
ENET0_MDIO <= '0';
wait for 400 ns;
ENET0_MDIO <= '0';
wait for 400 ns;
ENET0_MDIO <= '0';
wait for 400 ns;
ENET0_MDIO <= '1';
wait for 400 ns;
ENET0_MDIO <= 'Z';
report ("Done faking PHY response");
wait;
end process;
end;
