14 years agoSimulating the I2C Controller
Hello Everyone, I am trying to simulate the I2C controller, but have problem as there is no slave to generate the acknowlege back. Can Anyone tell me how to get around this. Thanks...
14 years agohello sir, and thanks for your quick response.
Yes I am trying to use the microphone to speak into the de2 board. so i need to create a controller(Master) in VHDL to control the slave(wm8731). Accordings the latter's data sheet, using a two wire transfer i need to send 3 bytes of codes, starting by: a start condition --> address of the slave --> ack(from the slave) --> register address --> ack (from the slave)--> data control--> ack(from the slave)-->stop condition. To do this i developed and FSM, that is going generates the proper clk and data signals. --> it specifies the start and stop conditions --> i created to counters to keep track of teh number of bits and bytes sent, and another one to divide the clk. --> to meet the timing requirements I divided cetain states to 2/3 states. --> since the sdin is bidirectional and open drain, to output logic one on the line it needs to be set to high impedence as follows sdin <= ‘z’ when sdin01 =’1’ else ‘0’ I think my code is okay, but i don't know how to simulate the acknowledgement from the slave. Should you be familiar with this protocol, please kindly advice me. Best Regards.
