Simulating L-Tile and H-Tile Avalon MM+ Intel FPGA IP for PCI Express using Questa
- 1 year ago
Thanks for the sharing of your conclusion and findings.
You're right. The simulation of S10 PCIe AVMM example design has problem which reports "FAILURE: Simulation stopped due to Fatal error!". After checked, the same issue exists in Q25.1 Pro as well. This is a bug that we need to fix.
Rong
Sorry for the delay.
The problem was with my Windows install, it has a space in a directory that has all my config data for all my programs. I ported the design over to CentOS 10, the latest update. It compiled in QuestaSim, took over 8 hours to simulate then failed. I used the design you sent me. I could not see any simulation waveforms.
Will try again.
If you don't mind, can you please append the WLF data? Once your simulation succeeds, it should post a message and ending the simulation run. I'm interested in the waveform data which you can save from the File menu. I can at least load this data in the advent there is another failure.
Thank you
