Simulating L-Tile and H-Tile Avalon MM+ Intel FPGA IP for PCI Express using Questa
- 1 year ago
Thanks for the sharing of your conclusion and findings.
You're right. The simulation of S10 PCIe AVMM example design has problem which reports "FAILURE: Simulation stopped due to Fatal error!". After checked, the same issue exists in Q25.1 Pro as well. This is a bug that we need to fix.
Rong
I finally find a way to upload the generated project. Please extract below files individually:
s10_ed.zip.zip --> s10_ed.zip
s10_ed.z01.zip --> s10_ed.z01
s10_ed.z02.zip --> s10_ed.z02
s10_ed.z03.zip --> s10_ed.z03
s10_ed.z04.zip --> s10_ed.z04
Put s10_ed.zip, s10_ed.z01, s10_ed.z02, s10_ed.z03, s10_ed.z04 into the same directory(e.g. ss) then extract s10_ed.zip to another directory(e.g. ../st). All .z0X files will be merged into one file called pcie_s10_hip_avmm_bridge_0_example_design_gen3x8dma_original.zip.
Hope this helps.
Rong
