Simulating L-Tile and H-Tile Avalon MM+ Intel FPGA IP for PCI Express using Questa
- 1 year ago
Thanks for the sharing of your conclusion and findings.
You're right. The simulation of S10 PCIe AVMM example design has problem which reports "FAILURE: Simulation stopped due to Fatal error!". After checked, the same issue exists in Q25.1 Pro as well. This is a bug that we need to fix.
Rong
The User Guide specifically mentions "No license is required", therefore it is free of cost to simulate including using the starter ed.
--On 7/17 we have aligned to AVMM PCIe IP, you're now discussing AVMM+ PCIe IP? My discussion with you so far is all based on the sim of AVMM PCIe IP.
--"No license requirement" in AVMM+ PCIe UG means this IP is free to use, and you can compile the design to get sof. Doesn't mean the Questa starter edition can handle such complicated simulation.
Rong
