RHobb
1 year agoSimulating L-Tile and H-Tile Avalon MM+ Intel FPGA IP for PCI Express using Questa
I'm following the user guide L-Tile and H-Tile Avalon MM+ Intel FPGA IP for PCI Express and using Questa Intel FPGA Edition to simulate. This is for Quartus Prime Design Suite 23.4. I followed the p...
- 1 year ago
Thanks for the sharing of your conclusion and findings.
You're right. The simulation of S10 PCIe AVMM example design has problem which reports "FAILURE: Simulation stopped due to Fatal error!". After checked, the same issue exists in Q25.1 Pro as well. This is a bug that we need to fix.
Rong
RongY_altera
Contributor
1 year agoI'm not able to upload an example for you to try because the zipped file is still too large. Splitting zip files can't be uploaded.
Rong
