Simulating L-Tile and H-Tile Avalon MM+ Intel FPGA IP for PCI Express using Questa
- 1 year ago
Thanks for the sharing of your conclusion and findings.
You're right. The simulation of S10 PCIe AVMM example design has problem which reports "FAILURE: Simulation stopped due to Fatal error!". After checked, the same issue exists in Q25.1 Pro as well. This is a bug that we need to fix.
Rong
can you also clarify,
After you changed into the testbench subdirectory, you typed in vsim, this brings up a window which expects you to put in the top level testbench to simulate. You don't mention any designs, you say you type vsim, then do msim_setup.tcl, then ld_debug and run -all.
I typed vsim in Questa or ModelSim, it just expects you to load the top level design.
That being said, I clicked on pci_ed_tb after typing vsim as the testbench file, but still couldn't load the design.
