Simulating L-Tile and H-Tile Avalon MM+ Intel FPGA IP for PCI Express using Questa
- 1 year ago
Thanks for the sharing of your conclusion and findings.
You're right. The simulation of S10 PCIe AVMM example design has problem which reports "FAILURE: Simulation stopped due to Fatal error!". After checked, the same issue exists in Q25.1 Pro as well. This is a bug that we need to fix.
Rong
I tried on linux using 1SX280HU2F50E2VG and Questa worked fine. The sim took a while to complete.
After synthesis, I went to pcie_ed_tb/pcie_ed_tb/sim/mentor, typed vsim there, then did "do msim_setup.tcl", "ld_debug" and "run -all" inside Questa.
If you check msim_setup.tcl, the QSYS_SIMDIR ./../ should point to the directory of pcie_ed_tb.v and common. I suggest you do the same thing with me. Go to pcie_ed_tb/pcie_ed_tb/sim/mentor and type vsim to start Questa there.
Rong
