Simulating L-Tile and H-Tile Avalon MM+ Intel FPGA IP for PCI Express using Questa
- 1 year ago
Thanks for the sharing of your conclusion and findings.
You're right. The simulation of S10 PCIe AVMM example design has problem which reports "FAILURE: Simulation stopped due to Fatal error!". After checked, the same issue exists in Q25.1 Pro as well. This is a bug that we need to fix.
Rong
I did the Analysis and Synthesis as recommended, and the design still does not compile.
The generated design does say it generated sucessfully.
Upon invoking vsim and running do msim_setup.tcl and ld_debug the last message says "Error loading design". Doesn't explain what file it can't locate or find. I've followed all instructions on p. 19-21 and still fails.
I was able to suppress other past errors as the paths to the design filed was over the 128 character limit on Windows, by
changing Windows environment variable LongPathsEnabled to "1".
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\FileSystem] LongPathsEnabled=1
Can you please confirm on your end by generating the design example for my device, 1SX280HU2F50E1VG, and using Questa it works?
Not sure why it's not loading the design?
