Simulating L-Tile and H-Tile Avalon MM+ Intel FPGA IP for PCI Express using Questa
- 1 year ago
Thanks for the sharing of your conclusion and findings.
You're right. The simulation of S10 PCIe AVMM example design has problem which reports "FAILURE: Simulation stopped due to Fatal error!". After checked, the same issue exists in Q25.1 Pro as well. This is a bug that we need to fix.
Rong
It looks like the failure happens during example design generation.
Line 358 of the text file shows your project path has a space, please fix this first then regenerate example design.
As p.19 says, turn on the Simulation and Synthesis options, for DMA design please Enable Avalon-MM DMA.
Rong
I got rid of the spaces, and again tried compiling the design in Questa. It has output a new error message and stops.
# ** Error: (vlog-7) Failed to open design unit file "../../../../ip/pcie_ed/pcie_ed_DUT/altera_pcie_s10_hip_avmm_bridge_2223/sim/pcie_ed_DUT_altera_pcie_s10_hip_avmm_bridge_altera_xcvr_pcie_hip_native_s10_2223_bbreury.v" in read mode.
# No such file or directory. (errno = ENOENT)
Since Intel has now obsolete static design examples, is there a legacy model that you can upload that I can use to simulate? I believe the problem exists when I don't have a Intel FPGA Board, but the Terasic Apollo S10 SOM which means I have to put no board design but otherwise put my chipset in and have a dynamic configuration and thats the problem. Can you try and put my chipset in an try to dynamically generate a design example and simulate it with no errors? 1SX280HU2F50E1VG
