Nanuq
5 years agoSimulating ASMI Parallel II
To be able to test our FPGA-Design in total, I’d like to connect a flash model of the S25FL128S with the ASMI Parallel II Core. I’m using a Cyclone V, and Quartus Version 18.1 Lite.
As fa...
YuanLi_S_Intel
5 years agoI was trying to duplicate your issue but no luck with it. Can you share me your testbench file?
Nanuq
5 years agoHi,
I attached the relevant files to this reply. I want to point out, none of the added files are written by me, some are generated by the IP Parameter Editor / IP Catalog, the cyclone V ones are installed when installing Quartus 18.1.
I still think that the problem is, that the entities of the ASMI Parallel II asmiblock and the Cyclone V asmiblock do not match.
But anyway, I decided to not simulate the ASMI Parallel II block but to access directly the Avalon bus, so I'm not working with this anymore.
