Simulating ASMI Parallel II
Before that, just want to check with your steps in setting up the simulation. Have you included the testbench and its setting before the compilation? You may refer to the link below for the steps.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_gs_msa_qii.pdf
- Nanuq5 years ago
Yes, I have included the testbench, and set the settings before compilation.
I am able to follow the signals in simulation through the files, from asmi_parallel.vhd to the submodules asmi_parallel_asmi_parallel2_top_0.vhd, asmi_parallel_asmi_parallel2_top_0_asmi2_core.vhd and altera_asmi2_qspi_interface.sv to the altera_asmi2_qspi_interface_asmiblock.sv (all of them compiled and simulated fine).
In the altera_asmi2_qspi_interface_asmiblock.sv, the cyclonev_asmiblock then cannot be found by the ModelSim. I did include the library "altera", but there, the only thing I can find (humanly readable) is the cyclonev_asmiblock_info.xml, and the ports defined there do not match the ports defined in the altera_asmi2_qspi_interface_asmiblock.sv, the SPI signals spidatain, spisce, spidclk and spidataout are missing.
