14 years agoSGDMA write_waitrequest always 'high'
Hello everyone, In order to achieve my project, I have to use my Nios II in order to send data from my FPGA to a server. My FPGA will have to read data from a Dual port Onchip memory which is c...
14 years agoThank you BadOmen, I followed your advices and I changed my streaming core ^^'
I also started my SGDMA and fed it with a valid descriptor but I still get the "ready" to 0. Even when I don't connect anything in the input of the SGDMA, the waitrequest is high and its ready signal is low. I saw that you had a similar discussion with Socrate in the following thread: http://alteraforums.org/forum/showthread.php?t=30273&page=2 My idea is to read the SGDMA ST data just like Socrate did but I don't get why my SGDMA is always waiting for an interruption that never happen because of the ready signal that is always low. Do you think that I should try to change my Onchip Memory with an DDR3 RAM ? (the same thing that is done with the TSE exemple)
