SGDMA to SDRAM speed?
[EDIT] SOLVED
Hello, I'm trying to develop an accelerator for a computer vision algorithm. The host program is running on the Intel Atom on the DE2i-150 board, and is sending images to the FPGA for processing. The problem is that I can't get more than 3 to 10MB/s throughput, which is quite small since the PCI-Express should be able to deliver something about 250MB/s, and the SDRAM should be even faster. My QSYS is pretty simple, you could see it on the attachment. I would appreciate if someone could help me with this. Is that a common issue? Can I be able to get more speed, something like 90MB/s or so? If so, how could I accomplish that? Many thanks.31 Replies
I think this example is very close to what you want: http://www.alterawiki.com/wiki/pci_express_in_qsys_example_designs. I'm wondering if you setup the dma_read_master and dma_write_master options correctly.
See if this example works for you. - Altera_Forum
I've came across this example when searching for something about mSGDMA. I've basically downloaded the qsys provided on this page and adapted it a bit, before trying to put the DC FIFO There were indeed some configurations I didn't know how to setup. For example:
Descriptor FIFO Depth on the mSGDMA Length Width on read master and write master Transfer Types under Memory Access Options on read master and write master - Altera_Forum
Can you try setting your dma setting like in the example? Let us know what happens.
Yes that was my first try. After that I tried to rewrite everything disabling some stuff like burst and it kept happening.
I'm starting to give up, but it doesn't make any sense since the PCIe should be fast enough even if bad configured, I think. And the same applies to the SDRAM. That's why I'm still trying. - Altera_Forum
Don't give up. dsl was talking about descriptors. Do you understand what they do? Maybe that is your bottleneck. If you aren't setting them properly then the dma won't process continuously.
Actually I don't understand much about this stuff, I'm starting out because of the Intel Embedded Systems Competitions (http://sbesc.lisha.ufsc.br/sbesc2015/intel+embedded+systems+competition). I've tried doing a LOT of research but the documentation seems to be sparse on what concerns these IP modules (PCIe, DMA, and many others). The best documentation that I've found was the "Video and Image Processing Suite User Guide", which is pretty good and deals with the whole Avalon-ST stuff but takes a lot to get to the point.
So, any help would be welcome when dealing with this. Long story short, I don't know how descriptors work. :( - Altera_Forum
One thing is that this PCIe communication is a huge problem here, everybody that I know that is competing have this problem. Solving this would be a big factor for us, and it seems that I'm the one who is digging deeper into this.
A descriptor is an instruction set that the master (in your case pc) gives the DMA that describes where to access data and how much data to take. In a memory-memory application like you have, the descriptor should contain the address locations of the source data (pcie) and the sink for the data (sdram) (or vice-versa) and the number of bytes to transfer in 1 pass or burst. With the mSGDMA you can write many descriptors into the descriptor buffer (see the dispatcher) and you can command the dispatcher to chain them: so once one descriptor is complete, the dma will automatically begin working on the next one. This way you can continuously transfer data.
Maybe this is a good overview: http://www.academia.edu/1741560/pcie_express
This is the same as the document on the alterawiki link - Altera_Forum
BTW, what board are you using? I assume its the cyclone iv gx fgpa development board. This board has a ddr2 sdram. If so, use this example: https://www.altera.com/support/support-resources/software/download/refdesigns/ip/interface/dnl-pciexpress-ddr3-sdram.html
Go to the link named: Qsys PCI Express to External Memory reference design for Cyclone IV GX This is probably exactly what you want.
