11 years agoSGDMA Interrupt
Hi, I'm having a major issue with the SGDMA component - the callback function that I've defined does not run. I'm not sure whether my code is flawed and I'm not calling the ISR function correct...
11 years agoI actually just added two FIFOs (my data is 32 bits wide, the internal FIFO on the SGDMA couldn't cope - it was only storing two words, and then writing), which solved the problem. I used one for data (4096 bits deep) and one as a clock bridge (my ADC is clocked to 25MHz, and my DMA and SDRAM run at 100MHz).
