11 years agoSGDMA Interrupt
Hi, I'm having a major issue with the SGDMA component - the callback function that I've defined does not run. I'm not sure whether my code is flawed and I'm not calling the ISR function correct...
11 years agoI'm tempted to say save yourself the hassle and write your own DMA controller. I got sick of trying to coax any of the DMA controllers in Qsys to work correctly, they either worked intermittently, not at all, or corrupted the data. Its only about a days work to write a decent DMA controller and at least if it goes wrong you wrote the source code so it's easier to fix/debug.
