15 years agoSGDMA data output issue
Hi, I just started to learn using sgdma to transfer data from DDR2. I have the sopc attached and please give me some idea if that is correct. Another issue is that I do not understand how ...
15 years ago1. Get your block done SOPC Builder with pin assigments.
2. Flash sof file 3. Use Nios IDE, C compiler to run simulate in real-time with hardware. Like, BadOmen shows you the link, but my main.c program should work on any sgdma to sdram memory. Sean.
