15 years agoSGDMA data output issue
Hi, I just started to learn using sgdma to transfer data from DDR2. I have the sopc attached and please give me some idea if that is correct. Another issue is that I do not understand how ...
15 years agoHi BadOmen,
Thanks a lot for your advice. But could you please go in more details about it? I have read the document and the sgdma seems working through the program below. But still how can I send the data to the hardware? Should I wire some pio to the sgdma? If possible can you show me some diagram/function call to get the data back to the hardware? Thanks! This is the program: int main() { int i; // int timeout=0; for (i=0;i<1000;i++) // buf initialization buf[i]=i%256; desc=(alt_sgdma_descriptor *)ONCHIP_MEM_BASE; // redefine the base address ? // ***************** open sgdma_tx ********************// sgdma_tx_dev=alt_avalon_sgdma_open(SGDMA_TX_NAME); if(!sgdma_tx_dev) { printf("ERROR: can't open TX SGDMA"); return -1; } // ***************** open sgdma_rx ********************// sgdma_rx_dev=alt_avalon_sgdma_open(SGDMA_RX_NAME); if(!sgdma_rx_dev) { printf("ERROR: can't open RX SGDMA"); return -1; } // ***************** reset RX SGDMA ********************// IOWR_ALTERA_AVALON_SGDMA_CONTROL(SGDMA_RX_BASE,ALTERA_AVALON_SGDMA_CONTROL_SOFTWARERESET_MSK); IOWR_ALTERA_AVALON_SGDMA_CONTROL(SGDMA_RX_BASE,0x0); // ***************** reset TX SGDMA ********************// IOWR_ALTERA_AVALON_SGDMA_CONTROL(SGDMA_TX_BASE,0); // Why these two are different here? IOWR_ALTERA_AVALON_SGDMA_CONTROL(SGDMA_TX_BASE,0xFF); // ***************** register rx callback ********************// alt_avalon_sgdma_register_callback( sgdma_rx_dev, (alt_avalon_sgdma_callback) &sgdma_rx_isr, // ? (alt_u16) ALTERA_AVALON_SGDMA_CONTROL_IE_DESC_COMPLETED_MSK | ALTERA_AVALON_SGDMA_CONTROL_IE_CHAIN_COMPLETED_MSK | ALTERA_AVALON_SGDMA_CONTROL_IE_GLOBAL_MSK, 0 ); // ***************** construct a descriptor for ST to MM transfer ********************// alt_avalon_sgdma_construct_stream_to_mem_desc( &desc[0], &desc[1], rx_payload, 0, 0 ); // ***************** construct a descriptor for MM to ST transfer ********************// alt_avalon_sgdma_construct_mem_to_stream_desc( &desc[2], &desc[3], (unsigned int*) buf, (256), 0, 1, 1, 0 ); // ***************** start sgdna_rx ********************// alt_avalon_sgdma_do_async_transfer(sgdma_rx_dev, &desc[0]); // ***************** start sgdna_tx ********************// alt_avalon_sgdma_do_sync_transfer(sgdma_tx_dev, &desc[2]); }
