SerialLite II protocol on Cyclone 10GX
- 5 years ago
Regarding your latest inquiry, my understanding is that there is no other protocol that can directly communicate with SerialLite protocol. Different protocols generally would not be able to recognize the data packets for example.
As I understand it, you have some inquiries related to the SerialLite support in the C10GX device. For your information, there seems to be no SerialLite IP supported in the C10GX devices. Sorry for the inconvenience. As a workaround, you might want to look into A10GX device which has the SeriaLite III IP supported.
Thank you for your return.
Is there any other IP on the C10GX device that have the same protocol as SerialLite ?
For instance : can an FPGA board with serialLite protocol communicate with another one (The C10GX) using another Protocol?
Best Regards
