LXI001
6 years agoSeriallite ii IP works in full duplex, stream mode. Although stat_rr_link is low, the data can still be received correctly. Whether or not in this mode, the connection is established independently of the indication of the pin
1 Reply
- Nathan_R_Intel
Contributor
Hie,
Could you help re-phrase your question as its not clear.
Are you having a concern that stat_rr_link is not asserted but data can be received correctly in full duplex mode?
The data can be received correctly if word boundary is determined on receiver side after word alignment is achieved.
stat_rr_link is status signal to indicate that link is enabled. Hence, for proper operation do ensure the stat_rr_link is asserted.
Nathan
Nathan
