James_B
Contributor
7 years agoSerial Flash Controller IP Clock Speed
I would like to confirm that the serial flash controller IP is only recommended to run at 25 MHz clock, as per the application note AN-736 on the website updated on 2016.05.20. My Nios currentl...
FawazJ_Altera
7 years agoYou are welcome.
HAlex
4 years agoHello
Just wanted to know if there are no clock domains issues when connecting Nios running at 100Mhz and Flash controller IP running in a slower speed?
I want to use Remote update and to program serial flash with an application image from Nios.
Flash controller IP currently connected exactly as shown on figure 3 above (to instruction and data master buses of Avalon).
Or I need to connect Nios and Flash controller IP through a bridge?
I am using EP4CGX150CF23C8N.
Thank you
Alex
