James_B
Contributor
7 years agoSerial Flash Controller IP Clock Speed
I would like to confirm that the serial flash controller IP is only recommended to run at 25 MHz clock, as per the application note AN-736 on the website updated on 2016.05.20. My Nios currentl...
FawazJ_Altera
7 years agoYou are welcome sir,
Kindly select as best answer if you are satisfied with my reply.
Let me know also if you need further assistance.
- James_B7 years ago
Contributor
FJumaah, Thank you for your answer. Yes, it is helpful. I will plan to use 2 clocks, one for Nios and one for the serial flash. I trust that there will be no clock domain crossing issues here.... Thanks, James
