SDRAM Throughput problems using Arria 10 SOC
Sorry, I still don't quite get your question here.
May I know are you changing your DDR3 IP operating frequency or DQ data width ?
- If yes, then I would expect more BW transfer
- If no, then I would expect the same BW transfer
My point is changing FPGA core clock frequency won't affect the BW transfer
dlim
--> for the above question also my answer is I changed my ddr3 operating frequency also from 600MHz to 750MHz still I am getting the same bandwidth or speed of transfer.
--> If we change or increase FPGA core clock frequency and supply more data then why not increase in the speed of data transfer because according to all the documents or datasheets shared by intel for burst mode atleast 60% efficiency i should suppose to get if I use everything upto the max. But I am getting hardly 30% efficiency only. May I know why or what factors affects this..?
