18 years agoSDRAM Controller
Now, i am researching about SDRAM Controller Core.So o need some document its.Can you help me? Many thanks
18 years agoInfo: *******************************************************************
Info: Running Quartus II Analysis & Synthesis
Info: Version 6.0 Build 178 04/27/2006 SJ Web Edition
Info: Processing started: Wed May 28 23:58:28 2008
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off sdr_ctrl -c sdr_ctrl
Info: Found 2 design units, including 2 entities, in source file sdr_ctrl_tb.v
Info: Found entity 1: sdr_ctrl
Info: Found entity 2: test_sdr_ctrl
Error (10228): Verilog HDL error at sdr_ctrl.v(4): module "sdr_ctrl" cannot have duplicate definition
Error: Entity "sdr_ctrl" in file sdr_ctrl_tb.v already exists in file sdr_ctrl.v
Info: Found 1 design units, including 1 entities, in source file sdr_ctrl.v
Info: Found 2 design units, including 2 entities, in source file sdr_sig_tb.v
Info: Found entity 1: sdr_sig
Info: Found entity 2: test_sdr_sig
Error (10228): Verilog HDL error at sdr_sig.v(8): module "sdr_sig" cannot have duplicate definition
Error: Entity "sdr_sig" in file sdr_sig_tb.v already exists in file sdr_sig.v
Info: Found 1 design units, including 1 entities, in source file sdr_sig.v
Info: Found 2 design units, including 2 entities, in source file sdr_data_tb.v
Info: Found entity 1: sdr_data
Info: Found entity 2: test_sdr_data
Error (10228): Verilog HDL error at sdr_data.v(6): module "sdr_data" cannot have duplicate definition
Error: Entity "sdr_data" in file sdr_data_tb.v already exists in file sdr_data.v
Info: Found 1 design units, including 1 entities, in source file sdr_data.v
Error: Quartus II Analysis & Synthesis was unsuccessful. 6 errors, 0 warnings
Error: Processing ended: Wed May 28 23:58:28 2008
Error: Elapsed time: 00:00:01
Error: Quartus II Full Compilation was unsuccessful. 6 errors, 0 warnings Can you help me to solve these error? I write a module named: sdr_ctrl and a test bench name sdr_ctrl_tb lile that: //**********************************************************************
// MODULE CHINH CONTROL INTERFACE
module sdr_ctrl(
sys_CLK, // clock he thong
sys_RESET,//reset he thong
sys_R_Wn,//read/write. High: chu ki doc Low: chu ki ghi
sys_ADSn,//sdram strobe
sys_DLY_100US,//tin hieu on dinh trong 100us
sys_REF_REQ,//tin hieu yeu cau refresh
sys_REF_ACK,//tin hieu ack tra ve
sys_CYC_END,//read/write da xong
sys_INIT_DONE,//tin hieu khoi tao
iState,// bien trang thai INIT_FSM
cState,// bien trang thai CMD_FSM
clkCNT); //phu thuoc vao burst lenght, cho biet so xung clock
input sys_CLK;
input sys_RESET;
input sys_R_Wn;
input sys_ADSn;
input sys_DLY_100US;
input sys_REF_REQ;//Tin hieu ngo vao
// OUTPUT
output sys_REF_ACK;
output sys_CYC_END;
output sys_INIT_DONE;
output iState;
output cState;
output clkCNT;//Tin hieu ngo ra
reg sys_INIT_DONE; // indicates sdr initialization is done
reg iState; // bien trang thai INIT_FSM
reg cState; // bien trang thai CMD_FSM
reg sys_REF_ACK; //tra ve ACK
reg sys_CYC_END; // read/write hoan thanh
reg clkCNT; //so xung clock
reg syncResetClkCNT; // reset ve 0
endmodule
and test bench module is: `include "sdr_ctrl.v"
module test_sdr_ctrl();
reg sys_CLK;
reg sys_RESET;
reg sys_R_Wn;
reg sys_ADSn;
reg sys_DLY_100US;
reg sys_REF_REQ;
wire sys_REF_ACK;
wire sys_CYC_END;
wire sys_INIT_DONE;
wire iState;
wire cState;
wire clkCNT;
sdr_ctrl sdr_ctrl_01(
.sys_CLK(sys_CLK), // clock he thong
.sys_RESET(sys_RESET),//reset he thong
.sys_R_Wn(sys_R_Wn),//read/write. High: chu ki doc Low: chu ki ghi
.sys_ADSn(sys_ADSn),//sdram strobe
.sys_DLY_100US(sys_DLY_100US),//tin hieu on dinh trong 100us
.sys_REF_REQ(sys_REF_REQ),//tin hieu yeu cau refresh
.sys_REF_ACK(sys_REF_ACK),//tin hieu ack tra ve
.sys_CYC_END(sys_CYC_END),//read/write da xong
.sys_INIT_DONE(sys_INIT_DONE),//tin hieu khoi tao
.iState(iState),// bien trang thai INIT_FSM
.cState(cState),// bien trang thai CMD_FSM
.clkCNT(clkCNT)//phu thuoc vao burst lenght, cho biet so xung clock
always begin
sys_CLK = 1'b0;
# 10 sys_CLK = 1'b1;
# 10;
end
initial begin
sys_RESET = 1'b0;
sys_R_Wn = 1'b1;
sys_ADSn = 1'b1;
# 15 sys_DLY_100US = 1'b1;
# 15 sys_REF_REQ = 1'b0;
# 400 sys_REF_REQ = 1'b1;
# 500 sys_R_Wn = 1'b0;
# 1000 $finish;
end
endmodule
