Bin_Wang
5 years agoSDI TX XCVR Failed to work
I am using the C10 GX105YF708 for SDI project.
For unknown reason, when I have both HDMI+SDI Tx core in the project.
The SDI tx_pll_locked and gxb_tx_ready will stay low..
HDMI TX core...
CheepinC_altera
5 years agoHi,
Sorry for the delay. Yes, you are right. I am referring to the XCVR user recalibration. If I understand it correctly, in C10 device, the Native PHY is a separate entity from the SDI II IP. You can perform the user recalibration through the dynamic reconfiguration AVMM interface.
As for the interference with the HDMI IP, sorry as I am not sure what might be wrong. Just wonder if you have tested using CMU PLL for the SDI and placing the SDI and HDMI in different XCVR banks just to help narrowing down the issue.
Chee Pin
