15 years agoSD-SDI RX clock recovery
Hello, I am trying to implement SD-SDI core to receive SDI signals. The transmitter part works fine, however I need receiver to do the same. I have connected SDI in and out signals to create a loo...
14 years agoBasically no, it is NOT correct. That valid signal usage as clock is workaround, not a solution. The solution is to use genlock. All SDI devices must use genlock to recover the clock.
