15 years agoSD-SDI RX clock recovery
Hello, I am trying to implement SD-SDI core to receive SDI signals. The transmitter part works fine, however I need receiver to do the same. I have connected SDI in and out signals to create a loo...
14 years agoHow do you monitor your clock? If you are controlling it in SignalTap, using it also as the sampling clock, it will show up as a constant signal
