9 years ago
SCFIFO simulation stucks
The following testbench stucks if SCFIFO has these parameters:
.USE_PACKETS          (1    ),
.USE_STORE_FORWARD    (1    ),
.EMPTY_LATENCY        (1    ),
.USE_MEMORY_BLOCKS    (1    )
It works fine if EMPTY_LATENCY is 3.
I haven't seen any notifications that it is forbidden to use EMPTY_LATENCY = 1 in this case. Did I miss something?
`timescale 1 ns / 1 ns
module tb_scfifo_2;
    localparam CLK_PRD = 10;
    localparam N_CH    = 1;
    logic               i_clk;
    logic               i_rst;
    logic       in_data           ;
    logic               in_valid          ;
    logic               in_startofpacket  ;
    logic               in_endofpacket    ;
    logic        in_empty          ;
    logic        in_error          ;
    logic               in_ready          ;
    logic       out_data          ;
    logic               out_valid         ;
    logic               out_startofpacket ;
    logic               out_endofpacket   ;
    logic        out_empty         ;
    logic        out_error         ;
    logic               out_ready         ;
    logic        csr_address       ;
    logic               csr_write         ;
    logic               csr_read          ;
    logic       csr_writedata     ;
    logic       csr_readdata      ;
    logic               almost_full_data  ;
    logic               almost_empty_data ;
    int unsigned        seed = 20;
    // Test
    // Clock
    initial
    begin
        i_clk = 1'b1;
        forever# (CLK_PRD / 2) i_clk = ~i_clk;
    end
    // Reset
    initial
    begin
        i_rst = 1'b1;
       # (CLK_PRD * 3 + 1) i_rst = 1'b0;
    end
    // Main sequence
    initial
    begin
        // Init signals
        in_data            = 1'b0;
        in_valid           = 1'b0;
        in_startofpacket   = 1'b0;
        in_endofpacket     = 1'b0;
        in_empty           = 1'b0;
        in_error           = 1'b0;
        csr_address        = 1'b0;
        csr_write          = 1'b0;
        csr_read           = 1'b0;
        csr_writedata      = 1'b0;
        out_ready          = 1'b1;
        $timeformat(-9, 3, " ns", 10);
        // Test sequence
       # 1;
       # (CLK_PRD * 10);
        for (int i = 0; i < 100; ++i) begin
            // SOP
            in_valid            = 1'b1;
            in_startofpacket    = 1'b1;
            in_data    = unsigned'($random(seed));
           # CLK_PRD;
           # (CLK_PRD * 3);
            // EOP
            in_endofpacket      = 1'b1;
           # CLK_PRD;
            // End
            in_valid            = 1'b0;
            in_data             = 1'b0;
           # (CLK_PRD * 3);
        end
       # (CLK_PRD * 20);
        $display("DONE");
        $stop;
    end
    // DUT
    altera_avalon_sc_fifo# (
        .SYMBOLS_PER_BEAT     (8    ),
        .BITS_PER_SYMBOL      (8    ),
        .FIFO_DEPTH           (1024 ),
        .CHANNEL_WIDTH        (0    ),
        .ERROR_WIDTH          (1    ),
        .USE_PACKETS          (1    ),
        .USE_FILL_LEVEL       (1    ),
        .USE_ALMOST_FULL_IF   (0    ),
        .USE_ALMOST_EMPTY_IF  (0    ),
        .EMPTY_LATENCY        (3    ),
        ) dut (
        .clk                  (i_clk               ),
        .reset                (i_rst               ),
        .in_data              (in_data             ),
        .in_valid             (in_valid            ),
        .in_startofpacket     (in_startofpacket    ),
        .in_endofpacket       (in_endofpacket      ),
        .in_empty             (in_empty            ),
        .in_error             (in_error            ),
        .in_channel           (in_channel          ),
        .in_ready             (in_ready            ),
        .out_data             (out_data            ),
        .out_valid            (out_valid           ),
        .out_startofpacket    (out_startofpacket   ),
        .out_endofpacket      (out_endofpacket     ),
        .out_empty            (out_empty           ),
        .out_error            (out_error           ),
        .out_channel          (out_channel         ),
        .out_ready            (out_ready           ),
        .csr_address          (csr_address         ),
        .csr_write            (csr_write           ),
        .csr_read             (csr_read            ),
        .csr_writedata        (csr_writedata       ),
        .csr_readdata         (csr_readdata        ),
        .almost_full_data     (almost_full_data    ),
        .almost_empty_data    (almost_empty_data   ));
endmodule
