Smith222122
4 years agoScaler II IP Core Causing Underflow on Clocked Video Output IP
Hello there,
I am having an issue with my Scaler IP core starving my Clocked Video Output (CVO) IP core and causing underflow. I think the issue stems from the scaler requiring a certain number of...
ZH_Intel
4 years agoHi Smith,
Thank you for your patience.
Yes I agree with Vgs, the rate is about 2 = ((1920x1080)/(1280x800)).
So the output valid signal will be asserted every two cycles.
I'm afraid the Input clock for Scalar II must be more than 124Mhz which is not included v-sync and h-sync.
Thank you.
ZulsyafiqH_Intel
