Rx word allign in high speed transceiver.
- 5 years ago
As I understand it, you have some inquiries related to the word alignment of the XCVR RX. Since it was not mentioned which specific Quartus version, FPGA device and IP used, I am assuming that you are uisng a Native PHY IP. Generally in the Native PHY IP, you should see some presets ie GIGE. You can apply the GIGE preset and check on the word alignment pattern used. You may need only 10bits word alignment pattern. You may try to get the simple GIGE preset running then slowly customize from there.
Thanks for your update. Glad to hear that you have managed to resolve the problem.
I believe the initial inquiry has been addressed. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
