running AN708 on Quartus 17.0
- 3 years ago
Hi David,
My apologies for late reply as my time is quite occupied these few days.
Thanks for your patience and the follow-up question.
Yes, the design is for hardware test rather than simulation test as mention in the user guide.
If you want to run the simulation, my suggestion is you can try to refer to the Arria 10 User guide
under section 2.1. Directory Structure and 2.4. Simulating the Design
Let me know if there is anything else that I can help you.
Wincent_Intel
Hi David,
Wincent_Intel
- dsun013 years ago
Contributor
Wchiah,
So, the demo is just show that Intel's core works. which nobody should doubt about. I will follow the Intel's idea, load the code to the board and use signal tap to track how the signals toggling.
thank you for the suggestion.
David
- Wincent_Altera3 years ago
Hi David,
I understand your feeling, you are free to doubt how it works.
But I just share some of my personal thought about this issue on this specific for this design example ONLY,
As you know sometimes there is an incident that happens as the simulation result is not the same as the hardware.There are multiple issues causing that to happen, for example, clock frequency on the board, Using delays in test bench design, timing checker wasn’t given the right clock rate, and other related reasons. To be honest, I do not have had a chance to go deeply into this design example and find out why the architecture is preferred to work well only in hardware instead of simulation yet at the moment, but I do understand it is to provide the most accurate test experience/result to the user specific to this design example .
If you need to simulate it, the simulation environment is provided Arria 10 User guide that is tested.
Apologies for any inconvenience caused to you.
Wincent - Personal thought
- dsun013 years ago
Contributor
if the auto created simulation environment doesn't work, it will be great to explicitly claim that in the AN708 to save some time for learner like me.
some designers like me always think Intel as a gold model. we will feel disappointed for any Non perfection. it is not Intel's problem at all.
Thank you,
David
