run AN708 on Quartus 21.3
- 3 years ago
Hi David,
I did some investigation and determined that Quartus 17.0 onwards don't allow test bench generation with critical hard blocks not connected. The reference design attached in AN708 was generated using Quartus 17.0 only. This Quartus version allows test bench generation with hip_pipe and hip_control conduit exported. My suggestion at the moment will be please revert back to Quartus 17.0 to use QYS feature to generate the test bench system.
To encounter this, I have opened an internal case to resolve this; so the AN708 simulation and test bench generation are also validated to allow migration. Hope the related team will work on this.
Please accept my apologies for the frustration you have faced. Hope this is clarified.Regards,
Wincent_Intel
Thanks for sharing with me.
for the Error: Unexpected error writing the ensemble: java.io.FileNotFoundException: issue
Normally You will receive the above mentioned error in the SOPC Builder if you have logged into a PC without admin priveleges
and you try and generate one of the example designs that is located in the default installation.
You can workaround this error by copying the example design from the installation directory into a new directory elsewhere on the PC.
Can you please try it ?
Wincent_Intel
by the way, could you duplicate the problem on your platform, if not, that means related to the tool installation. otherwise, is the project/software itself problem
thanks,
David
