run AN708 on Quartus 21.3
- 3 years ago
Hi David,
I did some investigation and determined that Quartus 17.0 onwards don't allow test bench generation with critical hard blocks not connected. The reference design attached in AN708 was generated using Quartus 17.0 only. This Quartus version allows test bench generation with hip_pipe and hip_control conduit exported. My suggestion at the moment will be please revert back to Quartus 17.0 to use QYS feature to generate the test bench system.
To encounter this, I have opened an internal case to resolve this; so the AN708 simulation and test bench generation are also validated to allow migration. Hope the related team will work on this.
Please accept my apologies for the frustration you have faced. Hope this is clarified.Regards,
Wincent_Intel
Thanks for sharing with me.
for the Error: Unexpected error writing the ensemble: java.io.FileNotFoundException: issue
Normally You will receive the above mentioned error in the SOPC Builder if you have logged into a PC without admin priveleges
and you try and generate one of the example designs that is located in the default installation.
You can workaround this error by copying the example design from the installation directory into a new directory elsewhere on the PC.
Can you please try it ?
Wincent_Intel
- dsun013 years ago
Contributor
I copied the project into a different directory, the software generates same error message.
by the way, I can run other very complex simulation with Jesd204b and DDR4 with Nios2 core without any problem.
I am learning PCIe now, don't know why I have this problem.
Thank you for helping.
David
- dsun013 years ago
Contributor
good news, after I change the owner of the directory, the original error disappeared.
bad news was that new errors appeared.
Error: can't read "intf_use_partner(pcie_rstn)": no such element in array
Error: Error: can't read "intf_use_partner(pcie_rstn)": no such element in array
Error: There were errors creating the testbench system.
- dsun013 years ago
Contributor
by the way, could you duplicate the problem on your platform, if not, that means related to the tool installation. otherwise, is the project/software itself problem
thanks,
David
- dsun013 years ago
Contributor
I set the testbench output directory to
C:/FPGA/aPcie/AN708_q170_projectCopy/top_tb/
why the tools want to update the files in the
C:\intelFPGA_pro\21.3\ip\altera\altera_pcie\altera_pcie_hip_256_avmm\channelizer\example_design?
- Wincent_Altera3 years ago
Hi Dsun,
Glad that the issue solve, are you using company workstation/computer ?
Suspect some file access routes might be encrypted...
For the new issue can you please remove all the unnecessary custom IP paths mentioned in IP Search Path and try to generate testbench again ?- dsun013 years ago
Contributor
Hi Wchiah,
How to find the IP search path? how do I know which is unnecessary?
by the way, can Intel provide a version of AN708 that can run with Quartus 21.3. I am learning generic PCIe IP by Intel example. I am not an Intel Platform expert. can I assume that there are not many people use Intel PCIe ip on latest quartus software.
if it is not straight forward to me, hard to believe it is an easy job for other engineers.
I really appreciate your help to solve this problem, should it be Intel's responsibility to provide a working example on the latest platform?
is the latest release based on Quartus 17?
Thank you,
David
