run AN708 on Quartus 21.3
- 3 years ago
Hi David,
I did some investigation and determined that Quartus 17.0 onwards don't allow test bench generation with critical hard blocks not connected. The reference design attached in AN708 was generated using Quartus 17.0 only. This Quartus version allows test bench generation with hip_pipe and hip_control conduit exported. My suggestion at the moment will be please revert back to Quartus 17.0 to use QYS feature to generate the test bench system.
To encounter this, I have opened an internal case to resolve this; so the AN708 simulation and test bench generation are also validated to allow migration. Hope the related team will work on this.
Please accept my apologies for the frustration you have faced. Hope this is clarified.Regards,
Wincent_Intel
Thank you for reaching out.
Just to let you know that Intel has received your support request and I am assigned to work on it.
Allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
Wincent_Intel
