13 years agoRemote Update over PCI Express
Hi, I'm currently developing a device which is connected to a PC over PCIe. My device has a JTAG connector which is planned to be used for an initial programming. But when the Device is in its ...
13 years agoIf you open up the MegaWizard Plugin-Manager, find the "ALTREMOTE_UPDATE" core, set a directory to generate the core to. After clicking next, the actual wizard for ALTREMOTE_UPDATE will launch. Here you will find a "Documentation" button on the top right, which links a couple of manuals on the topic for various parts. That should get you started.
The core does not help get a bitstream from PCIe into the flash chip - you need to solve that on your own. It simply provides a way to tell the on-board configuration logic to use an alternative base address for the next configuration load, and to cause a reconfiguration event from user logic. You can also separately use the core watchdog functionality, to cause a reconfiguration if a particular part of user logic locks up.
