13 years agoRemote Update over PCI Express
Hi, I'm currently developing a device which is connected to a PC over PCIe. My device has a JTAG connector which is planned to be used for an initial programming. But when the Device is in its ...
13 years agoSomehow the Alt. Remote-Update-Megacore takes care of which design should be loaded. First it loads a default-design which holds the Remote-Update and then it tries to load the "real design". But thar real-design should have the same components like the default-design.
The problem on "just load the flash over PCIe" is: - If the power fails during programming there is no way to flash it ever again. - If you forget to program this connection in your new design, you also can't flash it anymore. And this is the Idea of Remote-Update. You have a fallback-design which you never ever should change if it works. And from this design you can load every other design. But HTF does it work? ;) I have no idea.
