Danlar81's avatar
Danlar81
1 year ago
Remote Update on Cyclone V
I'm trying to understand and identify all of the IP cores required to perform a Remote System Update using a Cyclone V (5CEFA9F23I7N) with a MT25QL01 flash chip.
From what I have read it seems that I would require the following;
Remote Update Intel FPGA IP with Avalon MM support
Avalon MM Interface
Generic Serial Flash Interface Intel FPGA IP
Within the Remote Update user guide, it mentions you can bypass the Avalon MM interface, however this means I still need the ASMI Parallel II FPGA IP. The user manual for this core mentions it only supports EPCQ, EPCQ-L and EPCQ-A flash devices. Due to the flash I am using being third party it identifies the Generic serial flash mentioned above.
Have I got this correct?
Please advise.
Dan
  • Farabi_Altera's avatar
    Farabi_Altera
    "We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
    Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
    We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
    Thank you for your understanding."
    Farabi_Altera
    GSFI is the IP and AVMM is the interface to the IP from FPGA controller. GSFI is supercede of ASMI Parallel. So you will need AVMM to implement RSU.
    regards,
    Farabi
