Remote system upgrade in MAX10
Hi
i am using MAX 10 10M25DCF484C8G device and on chip flash (CFM) to store FPGA image.
i need to do remote upgrade this CFM through NIOS2.
i have refereed some document where Dual image IPcore used.
pof file size:773 kilobyte
rpd file size:773 kilobyte
FPGA CFM image size is 736 Kilobyte. i want to write two FPGA images(Dual configuration) in CFM(0&1).
Q1.is it possible to remote upgrade FPGA image in CFM through NIOS using ethernet?
Q2.one image RPD file size is 773 kilobyte and MAX10 FPGA (10M25DCF484C8G ) CFM size is 736kilobyte.
is it possible to compress two images and can load into CFM(0&1) for dual configuration?
Awaiting for quick reply
thanks
sathish
- JohnT_Altera
Hi Sathish,
Yes it is possible. We have example where it is using NIOS with UART (https://fpgacloud.intel.com/devstore/platform/15.0.0/Standard/an741-remote-system-upgrade-for-max-10-fpga-devices-over-uart-with-the-nios-ii-processor/).
Nope. You will need to store image 1 in CFM0 and image 2 into CFM1 and 2. Please refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_ufm.pdf table 1
- sRama28
Ans1: Thanks for UART example .please share the Remote upgrade system through Ethernet protocol.
Ans2: Understood your point .
one rpd file size is 773 kilo byte .
i referred the table .From the table the total CFM 0 total size is 736 kilo byte.
can i load two pof file in two location (CFM 0 and CFM1) ?
- JohnT_Altera
Ans1: We do not have example for Remote Upgrade Systme through Ethernet protocol.
Ans2: You will need to enable compression and it will fit into CFM0. CFM1 has lower size and it will need to include CFM2 to stored the full bistream.
