Moti's avatar
Moti
5 years ago
Reduce the DDR clock below 300 MHz
Hi
I use Quartus 20.3 pro for Stratix10 FPGA, DDR3 1600.
need to config clock below 300MHz at the IP.
at the DDR datasheet I found that I can run it slower.
I have attached the error I received, is it possible to configure the IP to support slower clock?
Moti
  • HI,
    Yup, as you can see from your own error screenshot, it's not supported.
    dlim
  • sstrell's avatar
    sstrell
    Are you saying you want to drive the external memory at a lower speed or run the internal logic at a lower speed? The internal logic runs, based on your current setting, at 1/4 the speed (quarter rate mode) of the external memory clock. If you're saying you want to run the external memory at a lower speed, then you can't, as the message indicates.
  • Deshi_Intel's avatar
    Deshi_Intel
    HI,
    dlim
