readyLatency of Arria 10 PCIe Avalon-ST IP
- 1 year ago
Hi Chenyang,
Thank you for sharing your detailed observations regarding the signal behavior of rx_st_ready and rx_st_valid.
You are right about the current IP settings in which both the RX and TX path has a readyLatency of 3. I observed the same from our Design Example generated from Quartus.
According to the User Guide, when it mentions a ready latency of 3 cycles, it does not mean the readyLatency must be exactly 3 cycles. Instead, it means the readyLatency can be up to 3 cycles. The user's Application Layer should be designed to handle the readyLatency up to the specified number, which is 3 in this IP.
Another way to check your readyLatency is via Quartus Platform Designer.
1. Open the .qsys file.
2. Go to View > Component Instantiation.
3. Locate the Arria 10/Cyclone 10 Hard FPGA PCIe IP.
4. Under Component Instantiation tab > Signals & Interfaces sub-tab > click rx_st signals.
5. You should be able to see the Ready latency value configured.
Arria® 10 and Cyclone® 10 GX Avalon® Streaming Interface for PCI Express* User Guide: https://www.intel.com/content/www/us/en/docs/programmable/683647/18-0/datasheet.html
I apologize again for my late response. I hope this has clarified your questions regarding the readyLatency of this IP.
Please let me know if anything remains unclear.
Ven
Hi Chenyang,
My apologies for missing your forum post.
Please allow me some time to investigate, and I will get back to you in 1-2 days.
Ven
