Read/Write EMIF DDR4
Hi, thank you for you answer,
I did as you mention, provide 0 data in the last burst which is not full.
Now the logic seems good, but I have the following issue :
master_write_data[255:0] is properly filled with fifo data, I can see it in signaltap. However the EMIF amm_write_data[255:0] (slave) which is directly connected to master_write_data[255:0] is equal to 0x0 ! I don't understand how is this possible, is it supposed to be the same net ?
For information, local calibartion is in success, no reset. The only thing that I can notice is that :
- waitrequest_n is always 0, so I can wait forever
- I am not sure if emif clock which is 266MHz on the DDR4 side should be the same as fifo clock which is for now 100 MHz,. Should I use the clk output from emif "usr_clk" as well as "usr_reset" to feed the fifo ? Can clock cross domain work ?
Thanks !
