How to properly constrain the PFL ? Differences between 2 docs. Which one is right?
Both documents state now :
eg https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf on page 28 :
Bidirectional synchronous: flash_data Read mode (PFL to Flash ROM) is listed here on page 28.
set_max_delay -from <port> -to pfl_clk
Is this right ?
PFL to Flash ROM direction looks to be output from the PFL (ie flash_data is out for READ mode. Isn’t this the case?) so the set_max_delay constraint suggested above should be :
set_max_delay -from pfl_clk -to <port>
Isn’t this the case here ?
Or I think :
Bidirectional synchronous: flash_data Read mode (Flash ROM to PFL) should be listed here on page 28 and NOT PFL to Flash ROM
set_max_delay -from <port> -to pfl_clk IS THEN CORRECT
Write Mode should then state (PFL to Flash ROM) and NOT Flash ROM to PFL
Is this correct?
- Knug5 years ago
Contributor
No reply here to this.
I also sent same message to the following private email BUT got back :
Delivery has failed to these recipients or groups:
[email protected] ([email protected])
Your message couldn't be delivered. Despite repeated attempts to deliver your message, querying the Domain Name System (DNS) for the recipient's domain location information failed.
