hls installation and getting started
Hi @Konrad,
Suspecting that the hls component are not able to detect the Visual studio installed.
Can you please try to running the init_hls.bat file in admin privileges command prompt and check/share on the output.
If the visual studio are not detected, would advise to reinstall in C drive if possible.
Please do let us know if that helps to clarify.
Best Wishes
BB
I do not know how to set the Visual Studio environment.
Visual studio is on my C:\ drive as a standard install (comunity free version)
C:\Program Files (x86)\Microsoft Visual Studio\2017\Community
Konrad
- BoonBengT_Altera5 years ago
Moderator
Hi @Konrad,
Based on the output from init_hls.bat, VS are not found.
And I notice that you are using HLS 19.1, for that it requires VS 2010. (as noted here)
Can you please try installing the VS 2010 pro and rerun the command, and I believe it should work.
Hope that clarify.Best Wishes
BB- Konrad5 years ago
I have VS 2010 Pro available at work but not at home. I have installed HLS 21.2 PRO.
Does this need a license or is it OK with Quartus Lite?
From what I have read it seems the HLS Pro is OK without Quartus Pro.
Anyway, when I run the tools they are still pointing to the HLS 19.1 compiler. The init_ .bat ran OK.
regards
Konrad
- Konrad5 years ago
Screen shot of the init_hls.bat
ps. I also have quartus 19.1 installed on my C:\ drive in the standard location...I opened and closed it prior to running to ensure it was the last version run, but the init_hls.bat seems to still pick up on the older version,
Konrad
