HBM2 interfacing with the PCI express hard IP STRATIX 10 MX
- 5 years ago
Hi, Sorry for the mistake.
I tried the same and I only can see the 16bits on the address. These address bits are affected by the setting of "Address width of bursting master" of the PCIe IP. I believe the developer hack the IP and change the address width to 30 instead.
If you need, you can change this by modifying the g3x16_hbm2_avmm_bridge_512_0.ip file.
Search for Address width of Bursting Master and you can change the value to 30.
Hi, Are you getting 403 access denied? I tried the same and get this error. I think the link should work, let me check with the internal team. From your side, maybe can see if there any link that you can click to "contact intel" and report to IT from external. Thanks.
Hi @BoonT_Intel , I am also getting the same 403 error. If you could get me the link that would be great. Meanwhile I will also try to file an intel IT request.
