GTS PMA/FEC Direct set-up
- 1 year ago
I'm not sure this question is posted into the proper forum, it seems more like an FPGA IP forum topic.
Where are the hex addresses defined from in the /src folder?
The example designs generated for the GTS IP generally connect one JTAG Avalon Master Bridge to the subordinate/slave interface of the IP core alone. So the address map that the system console scripts are accessing are defined by the GTS IP core itself. This is a rather complex core with multiple functions define a different base addresses within the IP core itself but you should be able to correlate the references that you see in the system-console scripts to the various register maps defined in the user guide.
Is there a standard way to go about integrating this example into a larger project?
This is a standalone design example that gets generated to evaluate the IP in this standalone configuration. There is no standard way to integrate this example into a larger project. Fundamentally, once you understand how the IP core operates in the mode that you're interested in using, you would then determine what makes sense from an implementation perspective to fit this functionality into your larger project. But since there are many different applications that the GTS can be integrated into, there is no standard way to do this. It's possible that you may find other system level example designs that would demonstrate a specific implementation of the GTS in that use case which may provide a better example of how it could be implemented in that specific use case.
- K6061 year ago
Contributor
Thanks @ProFromDover_Altera
Is it necessary to edit these AVMM registers in order to get a loopback running?
Or will the default loopback setting:
Suffice to get a loopback, along with this tx-rx serial setup:
... assign gts_i_rx_serial_data = gts_o_tx_serial_data; assign gts_i_rx_serial_data_n = gts_o_tx_serial_data_n; ... qsys_top soc_inst ( ... .intel_directphy_gts_0_o_tx_serial_data_o_tx_serial_data (gts_o_tx_serial_data), .intel_directphy_gts_0_o_tx_serial_data_n_o_tx_serial_data_n (gts_o_tx_serial_data_n), .intel_directphy_gts_0_i_rx_serial_data_i_rx_serial_data (gts_i_rx_serial_data), .intel_directphy_gts_0_i_rx_serial_data_n_i_rx_serial_data_n (gts_i_rx_serial_data_n), ... );Many thanks,
K
- ProFromDover_Altera1 year ago
Have you looked at section 6.12 of the GTS Transceiver PHY User Guide: Agilex™ 5 FPGAs and SoCs?
It states:
- The example design runs an external loopback test by default, with the loopback_mode parameter set to 0.
To perform an internal loopback test you must set the loopback_mode to 1 in the parameter.tcl file, located at: <design_example_dir>/hwtest/src/ - If needed, update the JTAG port ID by modifying the jtag_port_id parameter in the same file. The default value is 0.
- K6061 year ago
Contributor
I am looking now to parameter.tcl file, it looks like this:
# (C) 2001-2025 Altera Corporation. All rights reserved. # Your use of Altera Corporation's design tools, logic functions and other # software and tools, and its AMPP partner logic functions, and any output # files from any of the foregoing (including device programming or simulation # files), and any associated documentation or information are expressly subject # to the terms and conditions of the Altera Program License Subscription # Agreement, Altera IP License Agreement, or other applicable # license agreement, including, without limitation, that your use is for the # sole purpose of programming logic devices manufactured by Altera and sold by # Altera or its authorized distributors. Please refer to the applicable # agreement for further details. # (C) 2001-2024 Intel Corporation. All rights reserved. # Your use of Intel Corporation's design tools, logic functions and other # software and tools, and its AMPP partner logic functions, and any output # files from any of the foregoing (including device programming or simulation # files), and any associated documentation or information are expressly subject # to the terms and conditions of the Intel Program License Subscription # Agreement, Intel FPGA IP License Agreement, or other applicable # license agreement, including, without limitation, that your use is for the # sole purpose of programming logic devices manufactured by Intel and sold by # Intel or its authorized distributors. Please refer to the applicable # agreement for further details. set LINK_MNG_SIDE_CPI_REGS(0) 0xA403C set PHY_SIDE_CPI_REGS(0) 0xA4040 set LINK_MNG_SIDE_CPI_REGS(1) 0x1A403C set PHY_SIDE_CPI_REGS(1) 0x1A4040 set LINK_MNG_SIDE_CPI_REGS(2) 0x2A403C set PHY_SIDE_CPI_REGS(2) 0x2A4040 set LINK_MNG_SIDE_CPI_REGS(3) 0x3A403C set PHY_SIDE_CPI_REGS(3) 0x3A4040 set LANE_ADDR 0xA5000 set NUM_XCVR 0x1 set SET_SILB(0) 0x6A040 set SET_SILB(1) 0x6A140 set SET_SILB(2) 0x6A240 set SET_SILB(3) 0x6A340 set RESET_SILB(0) 0x62040 set RESET_SILB(1) 0x62140 set RESET_SILB(2) 0x62240 set RESET_SILB(3) 0x62340 set SET_LANE(0) 0x7A00F set SET_LANE(1) 0x7A10F set SET_LANE(2) 0x7A20F set SET_LANE(3) 0x7A30F set RESET_LANE(0) 0x7200F set RESET_LANE(1) 0x7210F set RESET_LANE(2) 0x7220F set RESET_LANE(3) 0x7230F set SET_MODE(0) 0xb1A003 set SET_MODE(1) 0xb1A103 set SET_MODE(2) 0xb1A203 set SET_MODE(3) 0xb1A303 set RESET_MODE(0) 0xb12003 set RESET_MODE(1) 0xb12103 set RESET_MODE(2) 0xb12203 set RESET_MODE(3) 0xb12303 set DIS_SET_SILB(0) 0x0A040 set DIS_SET_SILB(1) 0x0A140 set DIS_SET_SILB(2) 0x0A240 set DIS_SET_SILB(3) 0x0A340 set DIS_RESET_SILB(0) 0x02040 set DIS_RESET_SILB(1) 0x02140 set DIS_RESET_SILB(2) 0x02240 set DIS_RESET_SILB(3) 0x02340 set DIS_SET_LANE(0) 0x0A00F set DIS_SET_LANE(1) 0x0A10F set DIS_SET_LANE(2) 0x0A20F set DIS_SET_LANE(3) 0x0A30F set DIS_RESET_LANE(0) 0x0200F set DIS_RESET_LANE(1) 0x0210F set DIS_RESET_LANE(2) 0x0220F set DIS_RESET_LANE(3) 0x0230F set DIS_SET_MODE(0) 0x00A003 set DIS_SET_MODE(1) 0x00A103 set DIS_SET_MODE(2) 0x00A203 set DIS_SET_MODE(3) 0x00A303 set DIS_RESET_MODE(0) 0x002003 set DIS_RESET_MODE(1) 0x002103 set DIS_RESET_MODE(2) 0x002203 set DIS_RESET_MODE(3) 0x002303 set DISABLE_DSP_ADAPT(0) 0x40A00C set DISABLE_DSP_ADAPT(1) 0x40A10C set DISABLE_DSP_ADAPT(2) 0x40A20C set DISABLE_DSP_ADAPT(3) 0x40A30C set SNF_MODE(0) 0xA700C set SNF_MODE(1) 0xA7014 set SNF_MODE(2) 0xA701C set SNF_MODE(3) 0xA7024 set RX_ADPAT(0) 0xA7010 set RX_ADPAT(1) 0xA7018 set RX_ADPAT(2) 0xA7020 set RX_ADPAT(3) 0xA7028 set ux_q_lane(0) 0x9781C set ux_q_lane(1) 0x19781C set ux_q_lane(2) 0x29781C set ux_q_lane(3) 0x39781CIt seems there is not mentioned 'loopback_mode' or 'jtag_port_id'.
In section 6.6 I can see that the command sequence:
source main.tcl set_jtag <number_of appropriate_JTAG_master> run_test_silbShould perform an internal serial loopback, however for me I am seeing this:
Hi yes I did see this - after compilation, you can see here that after performing these commands in section 6.6:
% run_test_silb ----------------------------------------------------------- ----------------------------------------------------------- Link is not UP ----------------------------------------------------------- Apply RX reset: 0x00000022 Number of lanes : 1 1. 0x6A040 2. 0x0006a040 Polling Successfull Bit 15: 0x000001 , Bit 14: 0x000000 1. 0x62040 2. 0x00062040 Polling Successfull Bit 15: 0x000000 , Bit 14: 0x000000 Release reset: 0x00000000 Number of lanes : 1 Serial loopback on Lane# 0 is enabled PHY IP Setting : 0x0002c067 Scratch Register : 0x00000000 Soft Rst Crtl : 0x00000000 TX/RX/AVMM Ready : 0x00000010 TX PLL Locked : 0x00000001 CDR LTR & LTD : 0x00000001 RX ignore LTD : 0x00000000 Alarm status : 0x00000000 ----------------------------------- Value from issp reset probe is 0x45/0b1000101 -------------------------- Test Fail : Check the Link Status -------------------------- --------------- SILB TEST DONE ---------------- Apply RX reset: 0x00000022 Number of lanes : 1 1. 0x0A040 2. 0x0000a040 Polling Successfull Bit 15: 0x000001 , Bit 14: 0x000000 1. 0x02040 2. 0x00002040 Polling Successfull Bit 15: 0x000000 , Bit 14: 0x000000 Release reset: 0x00000000 Number of lanes : 1 Serial loopback on Lane# 0 is disabled
Maybe you know of what do do?
Many thanks!
